10-02-2003 10:53 AM - edited 03-02-2019 10:45 AM
I am trying to update the C2950 package from 4.0 to 5.0. The zip download gives the c2950 and nmidb zip packages. When I try to update using these zip'd files from the Staging Area, I get an eeeror that the Integration Utility is not configured on this server.
However, when I view the Application and Version under Server Configuration...I see Integration Utility 1.5 installed and enabled.
How do I get nmidb installed?
I am installing new, CW Common Services 2.2.
Solved! Go to Solution.
10-02-2003 06:30 PM
You may want to look at: http://www.cisco.com/kobayashi/library/cvplanner/Install_zip.shtml
10-02-2003 11:07 AM
uncheck the nmidb file from the list and it should work.
10-02-2003 06:17 PM
Yes, I've done that...however, the C2950 readme file talks about using the level of nmidb that this package contains.
So...should I be trying to update the nmidb with the new file? If so, how do I get this nmidb installed?
10-02-2003 06:22 PM
nmidb is only need if you have a 3rd party NMS application installed that you plan to integrate CW2K with.
10-02-2003 06:29 PM
Great..Thank you for the clarrification
10-02-2003 06:30 PM
