nmidb will not load when updating C2950 package
jcowtan
I am trying to update the C2950 package from 4.0 to 5.0. The zip download gives the c2950 and nmidb zip packages. When I try to update using these zip'd files from the Staging Area, I get an eeeror that the Integration Utility is not configured on this server.
However, when I view the Application and Version under Server Configuration...I see Integration Utility 1.5 installed and enabled.
How do I get nmidb installed?
I am installing new, CW Common Services 2.2.
5 Replies 5
rmushtaq
Level 8
Level 8
uncheck the nmidb file from the list and it should work.
Yes, I've done that...however, the C2950 readme file talks about using the level of nmidb that this package contains.
So...should I be trying to update the nmidb with the new file? If so, how do I get this nmidb installed?
nmidb is only need if you have a 3rd party NMS application installed that you plan to integrate CW2K with.
Great..Thank you for the clarrification
