Community Member
No HW and SW issue for Modul WS-X2924-XL-V on Cat2924
Cat2924M-XL-EN with installed modul didn't show the hw and sw version of that modul. It looks like
Module Ports Model HW Version SW version
2 4 WS-X2924-XL-V xxxx xxxx
Configuration register is 0xF
IOS is c2900XL-c3h2s-mz.120-5.WC3b.bin, should be ok. as described in hw/sw - Matrix.
Is that normal or something wrong ?
Ruedi
1 REPLY
Anonymous
N/A
Re: No HW and SW issue for Modul WS-X2924-XL-V on Cat2924
Hi Ruedi,
This is the normal behaviour. The card WS-X2924-XL-V(4 port 10/100 ISL/802.1Q switch module) does not run separate software,so it displays xxxx. Also the hardware version is not shown.
You could also check the release notes for this version if you have further queries regarding the code.
101
