no ip routing - command does not work on a sup720-3b
Cannot disable IP routing on a 6513 running IOS with a Super720-3B ,
I wish to run only layer 2 for now but as soon as i create a vlan with a IP address its start routing . No ip routing command comes up as not supported in this platform .
1 REPLY
Re: no ip routing - command does not work on a sup720-3b
It cannot be disabled by design since it turns off hardware forwarding. If you still wish too disable ip routing, you can do so after enabling "service internal"
Router(config)#no ip routing
% Invalid input detected at '^' marker.
Router(config)#service internal
Router(config)#
6d18h: %C6KFIB-4-DISABLED: Hardware FIB forwarding disabled, reverting to only software forwarding.
Hope this helps.
298
