No login pane when first installing CiscoWorks 2000. Helps !
I've first started installing CiscoWorks 2000 3th edition. But no login pane appears whenever I started navigated a client session to the Csw2000 server ! All I've seen was a grey pane on the left of the navigation place ! I've walked through all of the known problems but they did not make sense to this bug !Please help me ! Thanks ! Regards !
Blue
Re: No login pane when first installing CiscoWorks 2000. Helps !
What operating system?. NT/2000/Solaris?, If Windows, what Service Pack?. Fresh Install or Upgrade?. What web browser version?. Is Java, Java Script and Cookies Enabled in your web browser?
Nice one this one.... pull the windown separator to the right, the window is not large enough to view so it gets greyed out.
I've installed CD One 4th edition and the newest Patch with java-Plugin 1.3.1. . I have exactly the same problems.
I've no idea what's wrong. I've called my reseller and hope, that they will give me any hints. If i have an solution I will send you an email.
Michael Kemper
Dear all !
I've just passed through my login problem ! If you're using CiscoWorks 2000 on Windows 2000 and exactly match my problem, please give me your e-mail and I'll share my solutions to you :-) !
Regards !
Hi all,
the solution is to start the JRUN Proxy Server on the CW2000 Server. After the installation the Service wasn't started (because the startup type was manual ). After starting the service the LOGIN-Screen appears.
113
