Silver
No output for show running-config
12.0(5.30WC1
3548XL switch
When you do a show run, it doesn't display any output. When you do a sh config, it shows. You make a change to config, and do a wr mem, the change can be seen in sho config. But show run gives no output.
I have seen some bugs which says in low memory condition this problem could occur. This switch however doesn't have a high mem utilization.
Silver
Re: No output for show running-config
Irrespective of mem utilization, you need to have atleast 8MB of memory. Apart from bugs on less memory, I guess there should be no other problem.
is there any difference using sh run and write term commands?
From console or Telnet session?
Have you reloaded the switch?
Milan
304
