no "speed 10" command
Hi Cisco,
i have a 7206, NPE225 with IOS 12.4(5), and i want to change the speed on an FastEthIF manually to 10 MBit/s. That doesn´t work, even when i put in "half-duplex", and even if i put in "media-type rj45". Is it maybe not possible to reduce the speed on an FastEthIF to 10MBit/s?
Kind regards, Philip
1 REPLY
Re: no "speed 10" command
What kind of FE card do you have? Issue a sh diag to check. Certain FE cards do only 100Mbps and cannot do 10 Mbps
http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a0080094ea3.shtml#io-board
For example, the C7200-I/O-FE-MII card I have in my lab 7200 cannot do 10Mbps.
7200-1#sh diag 0
Slot 0:
Fast-ethernet on C7200 I/O card Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 5w5d ago
EEPROM contents at hardware discovery:
Hardware revision 1.3 Board revision C0
Serial number 6731099 Part number 73-1537-03
FRU Part Number: C7200-I/O-FE-MII=
Test history 0x3 RMA number 14-16-90
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 14 01 03 00 66 B5 5B 49 06 01 03 03 0E 10 5A
0x10: 60 00 00 00 97 10 21 00 00 00 FF FF FF FF FF FF
7200-1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
7200-1(config)#int fas0/0
7200-1(config-if)#speed ?
% Unrecognized command
104
