No Slot0: in rommon mode
I'm using a Catalyst 6509 with a Sup2 engine. The Sup card has a PCMCIA card that's accessible when I'm in the switch mode. However, when I go to rommon in Router mode, I can see bootflash: but not the slot0:
Any Idea?
Thanx
  • Other Network Infrastructure Subjects
Re: No Slot0: in rommon mode
Slot can't be access from the MSFC rommon..
By the way why you want to use the slot0: from the MSFC. Are you running the CAtos or the Native IOS
I'm using CATos. The image in bootflash: is corrupted and I get dummped into rommon. I'm trying to somehow get a image into bootflash:. I know it can be done through console connection using xmodem command, but it take a long time.
Thanx,
What does the switch display when you type in "dir slot0:"?
97
