Webcast-Catalyst9k
Nortel Switch and Cisc 3825 routing
Hi Guy,
Would appreciate if you could provide some feedback for this setup
Nortel Switch(A)------>Cisco 3825
Nortel Switch(B)----------|
Is that possible connecting 2 Nortel Switch(A) and Switch(B) with cisco 3825 load balance and fail over?
FYI. The cisco 3825 is using static route.
Appreciate and thanks for your helps.
1 REPLY
Purple
Re: Nortel Switch and Cisc 3825 routing
You can certainly do load-sharing in this scenario. Could you provide details on exactly what you are trying to achieve ?
Paresh
102
