not able to send or receive packets
I am un able to send or receive packets across my WAN. Surprisingly the statics of the show interface command of routers on both ends of the WAN shows something like this.
Serial1/3 is up, line protocol is up
Hardware is CD2430 in sync mode
Description: Connecting NTCHEU CCC
Internet address is 192.168.40.6/24
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec, rely 135/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang 5d22h
Input queue: 0/75/0 (size/max/drops); Total output drops: 699
Queueing strategy: weighted fair
Output queue: 0/1000/64/679 (size/max total/threshold/drops)
Conversations 0/50/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
255018 packets input, 16955412 bytes, 0 no buffer
Received 106160 broadcasts, 0 runts, 3 giants, 0 throttles
5932220 input errors, 3520772 CRC, 0 frame, 0 overrun, 0 ignored, 2411421 abort
366882 packets output, 112003269 bytes, 0 underruns
0 output errors, 0 collisions, 140948 interface resets
222 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
On the other end of the WAN the Serial interface of the router has 192.168.30.22 as its ip address and interface statics show that the line protocol is up as well. The line I am using is a 14.4k inetrfaced by codex modems.
Would anyone know what could be causing this surprising scenario?
Bronze
Re: not able to send or receive packets
One could be the high number of input errors, CRC, and interface resets from the show interface command output. Another is that the two serial interface IP addresses do not belong to same network and I assume you cannot even ping the serial interface, both sides, even if it shows "UP", "UP".
Here's the link for troubleshooting serial line problems:
http://www.cisco.com/en/US/tech/tk713/tk584/technologies_troubleshooting_procedures09186a00800a758d.shtml
HTH.
Gold
88
