Not able to use NetConfig to config. device
I encounter the following error msg when using NetConfig to configure Cat Switch (model: WS-C2924M-XL, c2900XL-c3h2s-mz.120-5.WC3b.bin)
Error Messages as follows:
"Device was successfully downloaded, Sync Archive failed
Device manage:No Rollback Change Required
---Update Result: Partially Successful
PGN_NM=Configuration Archive:6775:TYPE=unassigned message type:Failed to get running config. for device...
From RME Drawer, Administration, Conf. Mgmt, Archieve Status. There is not reported for this device?
Blue
Re: Not able to use NetConfig to config. device
RME version?
RME3.4, IDU Version 4-0
Blue
Increasing the SNMP timeout in RME is one thing to try and then re-try again. Is this device setup with the standard > and # prompts for telnet/enable?
I have set the SNMP timeout to 120 sec and still getting the same error.
Also, I notice that my running-config has been changed on the device, for example, I want to change my banner motd on the device, after executing the Netconf with my own customize MOTD, the old banner gets removed and the new MOTD is not being config. on the device. Why is this so?
P.S. the device prompts is the standard > & #.
Blue
This may require some detailed troubleshooting. TAC can help you with that.
eap
Did you ever get a solution to this? I am having the same problem.
Paula
178
