'Not applying Output Acl for packet tcp srcHost x.x.x.x dstHost x.x.x.x'?
This type of message suddently appeared on a Layer 3 Cat4. What could be the cause?
thanks
1 ACCEPTED SOLUTION
Re: 'Not applying Output Acl for packet tcp srcHost x.x.x.x dstH
This is from Cisco,
1. %C4K_PKTPROCESSING-5-NOTAPPLYINGACL: Not applying [input/output] Acl for packet [packet-info]
This message indicates that the software has not taken the ACL actions because it could not determine the correct ACL entry that is indicated by the hardware. The hardware-provided index of the ACL content-addressable memory (CAM) indicates that the software needs to take the actions for the entry at that index. If the packet was queued in the hardware before being processed by the software, the index is out of date.
Recommended Action: This message is informational only. No action is required.
More explanation required thou....
Do the src and dst host addresses of traffic hitting the switch match an ACL you added recently? In this case match on tcp any any? Or any other specific ACL entry in a message? It may be that the ACL didn't get programmed into HW. Try removing and reapplying the ACL.
This is from Cisco,
694
