Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Novell connectivity problem in Catalyst 2950 Switch
We have purchased new 2950 switches but we are unable to connect the pcs with novell netware v3.12 server. we are using 3com's ISA network adapter in server and 3com's 3c905b network adapter in workstations. What should i do to solve this problem
1 REPLY
Purple
Re: Novell connectivity problem in Catalyst 2950 Switch
Did you turn on portfast for all your client pc"s ? It's possible that your clients are timing out before spanning tree puts the port into forwarding state . For each port use the "spantree portfast" command .
110
