npe-g1, ip accounting, cpu problems
hy,
i am testing a npe-g1 in the moment and i have to use ip accounting outgoing-int on the box.
i use the 12.2(14)S IOS (also tested the 122-4.BW1) and when i increase
the ip accounting-threshold to 100000, the cpu goes to 100%.
i use a small DOS-tool to make some traffic, as we are an ISP and the router
will be DOSed, when he is in production. i generate 33kpps with spoofed
source-ips.
without the ip accounting, the cpu goes only th 16%, with ip accounting
nearly to 100.
CPU utilization for five seconds: 98%/98%; one minute: 98%; five minutes: 67%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
it seams that if i make a clear ip accounting, all packets are process-switched and after a while, they hit the route-cache.
any hints how i can remain with an ip accounting-threshold of 100.000
and a normal cpu utlilization?
kind regards,
marco
Gold
Re: npe-g1, ip accounting, cpu problems
You aren't process switching these, since all of your processor is taken up under the interrupt context (98/98). Check show alignment to make certain you aren't getting a ton of alignment errors or spurious accesses. If you aren't this box is just sucking up all its cpu in cef switching.
Russ
hy,
here the output with the sh alignment. there are no alignment errors...
npe#sh proc cpu | e 0.00
CPU utilization for five seconds: 95%/95%; one minute: 32%; five minutes: 8%
npe#sh alignment
No alignment data has been recorded.
No spurious memory references have been recorded.
npe#sh int gi 0/2
30 second input rate 4964000 bits/sec, 10659 packets/sec
30 second output rate 4964000 bits/sec, 10658 packets/sec
but 100% cpu just for cef-switching? *ouch*
marco
253
