11-28-2003 05:45 AM - edited 03-02-2019 12:01 PM
Having a 7206vxr w/NPE-G1 connected with gigabit to Cat3550-12g (Layer2 only, ios 12.1(13)EA1a). After some hours the router drops all outgoing traffic to the 3550. Looks like input to the router works. Workaround: clear interface or sh/no sh. Tried both fiber and rj45. Tried different ports. Tried different 3550 switches. 7200 is running 12.3(3a).
Anyone experienced something like this?
12-01-2003 07:52 PM
I have seen this, and the end-all cure for this was a code upgrade. You may want to check with TAC about your issue.
(0_o)
12-02-2003 04:09 AM
Interesting. Do you know if there is any DDTS for it? Or do you know which code it is fix in?
Tac is involved in this case. Please advise.
12-02-2003 04:21 AM
I am looking for my past info on this but basically,interface Input queue wedges because of RARP packets" Will continue to look.
12-02-2003 05:07 AM
Found a ddts for rx input queue: CSCea57826. Is this the same as in your case.
