NTP issue on cat6509
I'm unable to sync my router with cat6509. The cat6509 is synced with NTP server on the net and has following config
ntp
set ntp client enable
set ntp server 158.43.128.33
set ntp server 158.43.128.66
The Cat6509 sync fine. But if I want to sync my router on the Lan with the
switch its not working. Any idea how I can do this ?
router config is
ntp source FastEthernet1/0
ntp server 10.199.1.251
ntp server 10.199.1.252
Atul
Silver
Re: NTP issue on cat6509
Can you ping the 10.199.1.251 & 252 addresses from the router sourcing your ping from f1/0 ?
Yes it is pingable
69
