Community Member
NTP not working on catalyst 4506
I configure ntp to work on catalyst 2950, it work well. I use the same command on catalyst 4500 but it doesn't work. I use the command "ntp server 192.168.1.1"
The catalyst 4506 run with IOS and have many VLAN configured.
I would like to know if the catalyst 4506 need more specific command to work with NTP.
thanks very much
VIP Purple
Re: NTP not working on catalyst 4506
I assume you have tested if you can reach IP address 192.168.1.1 from your 4506, that is, you van ping that address.
Can you post the output of the commands:
show ntp status
show ntp associations
GP
Community Member
Cisco#show ntp associations
address ref clock st when poll reach delay offset disp
~192.168.11.170 0.0.0.0 15 1 64 176 4.0 34395. 383.7
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
Cisco#show ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 249.9969 Hz, precision is 2**7
reference time is C3B0E9EC.A2CE56C1 (11:29:00.635 CEST Thu Jan 15 2004)
clock offset is -185.9525 msec, root delay is 8.03 msec
root dispersion is 386.20 msec, peer dispersion is 117.08 msec
388
