Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
jum
NTP problem: insane source
I have a router synchronized to a time server and a few
2950 switches synchronized on the router. When I enter the command "ntp server ..." on the 2950, the synchronization occur but after 2 or 3 minutes the router appears as insane, invalid.
If I configure a "no ntp server" and then re-enter the same ntp server, the synchronization occur again but just for 2/3 minutes.
Is anybody have a idea?
Bronze
Re: NTP problem: insane source
Link doesn't work...
I have a similar problem with IOS Access Points [12.2(13)JA1]. I'm using a FreeBSD 5.1-release machine as an ntp server; APs sync fine, but eventually lose sync, reporting my ntp server as 'insane.' Killing and restarting ntp on the AP fixed the issue for a while.
jum
I think I have the solution. Just enter a "no ntp clock-period" to force the IOS to to revert to default the parameter and re calculate it. It solves my problem.
419
