Community Member
NTP process taking 10% of CPU utilization
Hi All,
I have a issue with my Catalyst6509,
NTP is taking 10% of cpu utilization. I have removed all the NTP configuration from Catalyst. still CPU Utilization is not reduceing
Any idea how to restart NTP process
Madan.
Silver
Re: NTP process taking 10% of CPU utilization
Is it keep receiving NTP packet from somewhere ? I think only remove and add the NTP command will restart the process. If it does not work, you may need to restart the chassis.
Hope this helps.
If after removing process your utilisation is still 10% and those 10% are actually taken by NTP process, then it looks like dormant process and probably requires restart of the supervisor engine. Before restarting you may want to search Bug Navigator for NTP bugs or/and open TAC case.
If after removing NTP 10% are actually occupied by something else (or mentioned after / in first line of sh proc cpu output), then surely it's not NTP process itself but might be traffic that eroneously ended up in NTP process.
408
