Community Member
NTP Router Problem
Hi every body
I need your recommendation at my Network problem which is
At our Network we have Cisco Router 7505, acts as NTP server for all 6 Cisco Routers 25xx series and 2 Cisco Switches 5505.
When summer time starts the NTP Router changed its time automatically, for the other routers, there were two of them are unsynchronized but the other 4 Routers are synchronized, also the 2 switches 5505 have no automatically option to change their time.
So my questions are
1-How to adjust the time of 2 switches 5505 also make them synchronized with NTP Router 7505?
2-How to troubleshoot the synchronous of the 2 routers 25xx with the NTP Router 7505 ?
best regards
omy
1 REPLY
Re: NTP Router Problem
So my questions are
A: set summertime enable [zone_name]
set summertine recurring
This example shows how to set the clock adjusted for Pacific Daylight Time following the U.S. standards:
Console> (enable) set summertime enable PDT
Console> (enable) set summertime recurring
Summertime is enabled and set to 'PDT'
Console> (enable)
A: Same, you alos need to configure 'summertime' on the router.
Please rate all posts.
206
