OC-3 Cross Connect
We have a 7200 Wich has an ATM OC-3 interface with multiple PVCs. We want to peel off some of these PVC and cross connect them through a HSSi interface to a router on the inside of our firewall. While still terminating some other PVCs on the 7200. Is this supported on the 7200 and is there any docs on-line to show config examples? Thanks.
1 REPLY
Re: OC-3 Cross Connect
Greetings!
HSSI will not support ATM PVC. If you are trying to use HSSI for ATM. You may use ATM-DXI which require ADSU in the middle to run ATM application.
Here is the example of how to use serial for ATM application:'
http://www.cisco.com/en/US/tech/tk39/tk371/technologies_tech_note09186a00800d73ba.shtml
Warmest Regards,
Bessie
107
