ODR and Frame Relay
1.Does ODR supported on Frame-relay network ?
2. Can we enable Dial-Backup at spoke router in ODR implimentation?
1 ACCEPTED SOLUTION
Bronze
Re: ODR and Frame Relay
1. ODR is supported by any medium that supports CDP, including frame relay.
2. You can enable dial-backup at an ODR-enabled spoke router. You must set up the primary interface with a backup interface. Floating statics will not be an option for your dial-backup scheme since, with ODR, the spoke router receives no routing information over the primary link.
Hope this helps.
Mark
Bronze
Hope this helps.
Mark
If the medium is Frame Relay, we may not be able to use backup interfaces
since even if the PVC is down, the physical interface may be not down.
106
