Community Member
ODR routing and ping
using 1 3640 as the hub router; multiple 2610 routers as the spoke routers. running ODR on the hub and a static default route (0.0.0.0 0.0.0.0 ser0/0) on the spoke routers. Also using IP unnumbered on the 3640 WAN ports with them referencing the IP address of the eth0/0 port. I can ping across the WAN host to host but I can't ping the hub router from the spoke routers. Is it because of the IP unnumbered or what? Any help would be greatly appreciated.
1 REPLY
Community Member
Re: ODR routing and ping
You'll probably need to debug icmp to see if the packets are ariving at the destination routers but before that, try doing an extended ping sourcing off a valid router IP address.
78
