07-05-2002 07:34 AM - edited 03-01-2019 11:35 PM
I need to replace the 8-port T1 PA's in a 7513 VIP with a Multichannel T3 PA, and re-deploy the T1 PA's to a 7206. As I understand OIR, all I'll need to do is:
1. Remove the VIP from the running 7513
2. Swap out the PA's
3. Re-insert the VIP
4. Configure the PA-T3
and on the running 7206:
1. Insert the PA-8T
2. Configure the PA-8T
Any "gotcha's" with this procedure?
07-05-2002 07:45 AM
CBUS Restart will occur and service will be interupted for a short time unless you have code that supports SLCR. Here is a link to explain.
http://www.cisco.com/warp/public/63/cbus_complex.html
Hope this helps,
Don
07-05-2002 08:15 AM
Thanks Don,
We loaded 12-1(13) when we initially installed the VIP's so we should be ok on that score.
07-05-2002 12:18 PM
SLCR is not in Mainline until 12.1.14 so your 12.1.13 should not be able to support this feature. Also you need to enable this, it is not on by default.
service single-slot-reload-enable globally will turn this on.
Here is a link.
Also here is a link to the Feature Navigator that shows what feature is in what IOS version.
http://www.cisco.com/cgi-bin/Support/FeatureNav/FN.pl
Hope this helps,
Don
