09-20-2006 03:20 PM - edited 03-03-2019 05:08 AM
Greets all -! need assitance with the pw recovery of an old 2500 router.
I have tried the usual ctrl-break after power cycling but it will not go into rom mode
the ios on it is 11.1(24) any hints tips or tricks? i have also tried several pc's thinking the keyboard was messed up but still the same result
i keep tapping that ctrl-break while boot up and also tried tapping it just once.. same results just ignores it..
09-20-2006 03:38 PM
If you are trying to use hyperterm get rid of it and download Tera Term off the web . Have never had it fail , do the letters look ok while it starts to boot ? Can you read it ? If so then it is a hyperterm problem with the control break which is well known.
09-20-2006 04:10 PM
Hyperterm seems to fucntion fine.. besides terra term "seems" to supprt up to com port 4.
09-20-2006 04:46 PM
Pete,
Please refer the below URL for password recovery on 2500 router.
Also, below is the link to Standard Break Key Sequence Combinations During Password Recovery
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
I hope it helps.
Arul
09-20-2006 05:20 PM
thanks but I already looked at those before i posted it here. Still have the issue.
09-20-2006 06:57 PM
Pete
The symptoms that you describe seem to be consistent with the behavior of the standard version of Hyperterm distributed on Windows PCs. I would suggest that you load the enhanced version of Hyperterm or try some other terminal emulator (I have had good experiences with TeraTerm, I have had good experience with SecureCRT, there are many terminal emulators available).
Try a different terminal emulator and let us know whether the behavior changes.
Rick
