You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
OLD-CISCO-CHASSIS-MIB variable cardOperStatus
On CATOS switches we use the CISCO-STACK-MIB variable moduleStatus as follows, this works fine :
plato> snmpwalk -m CISCO-STACK-MIB -v 2c cat102 'mialaz&' moduleStatus
enterprises.cisco.workgroup.ciscoStackMIB.moduleGrp.moduleTable.moduleEntry.moduleStatus.1
= ok(2)
On an IOS(Cat4K) switch there is no CISCO-STACK-MIB support instead we use OLD-CISCO-CHASSIS-MIB with variable cardOperStatus , this does not work :
% snmpwalk -m OLD-CISCO-CHASSIS-MIB -v 2c cat211 'mialaz&' cardOperStatus
enterprises.cisco.temporary.chassis.cardTable.cardTableEntry.cardOperStatus
= No Such Instance currently exists
How can we read the module status on an IOS based switch?
Thanks.
  • Other Network Infrastructure Subjects
Blue
Re: OLD-CISCO-CHASSIS-MIB variable cardOperStatus
Cat4K runnung IOS does not support OLD-CISCO-CHASSIS-MIB: ftp://ftp.cisco.com/pub/mibs/supportlists/cat4000/cat4000-supportlist.html
Use ENTITY-MIB instead
Entity MIB only provides information about the inventory information such as serialnumber, name, description to name a few. However cardOperStatus cannot be had from Entity-MIB.
Is there any alternate solution available to monitor the card Status ?
436
