One port of 2950G attached to a hub is not forwarding,why?
Hello,in my network,a 2950G-24 switch is attached to a Hub,distance between them is near 100m,the connection port in 2950G-24 is configured to 10m and half -duplex.After a uncertain time,the port led is solid amber,status of the port is line down and protocol down.After re-plug out and in the cable,the port become ok.Why?can you tell me how to resolve this problem?Thanks.
Re: One port of 2950G attached to a hub is not forwarding,why?
Does the interface see lot of collisions? If so, the port might be error disabling. Can you paste the output of sh interface fastethernet 0/x
Following is the output on 2003/02/12 and 2003/02/24.
2003/02/12
FastEthernet0/26 is up, line protocol is up
Hardware is Fast Ethernet, address is 0009.b7ce.8e5a (bia 0009.b7ce.8e5a)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Half-duplex, 10Mb/s
input flow-control is off, output flow-control is off
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
25072 packets input, 5918241 bytes, 0 no buffer
Received 2620 broadcasts, 0 runts, 0 giants, 0 throttles
155221 packets output, 30164967 bytes, 0 underruns
4 output errors, 1478 collisions, 3 interface resets
0 babbles, 0 late collision, 1136 deferred
0 lost carrier, 0 no carrier
Following is the output on 2003/02/24.
2003/02/24
Keepalive not set
Half-duplex, 10Mb/s
Last input never, output 00:00:00, output hang never
314106 packets input, 37827763 bytes, 0 no buffer
Received 10300 broadcasts, 0 runts, 0 giants, 0 throttles
1230378 packets output, 628467177 bytes, 0 underruns
4 output errors, 38347 collisions, 3 interface resets
0 babbles, 0 late collision, 26217 deferred
93
