original of cisco device
rifki
my catalyst 3548 xl series have a problem. if i turn on, then pwr and status light on. after few second the catalyst restart it self. did my catalyst was bad....
how to find the 'mark' of cisco device which original from cisco, did cisco attach the document and guarante license in every cisco device
Prashanth Krishnappa
If you are looking to determine part number, a sh ver should tell you the exact model number. I suggest that you open a TAC case to troubleshoot if it's a bad switch or a software issue
Switch#show version
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.4)WC(1), MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Tue 10-Jul-01 12:32 by devgoyal
Image text-base: 0x00003000, data-base: 0x00333CD8
ROM: Bootstrap program is C3500XL boot loader
Switch uptime is 3 days, 7 hours, 41 minutes
System returned to ROM by reload
System image file is "flash:c3500XL-c3h2s-mz.120-5.4.WC.1.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID FAA0412H0NC, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:01:42:FF:09:C0
Motherboard assembly number: 73-3903-04
Power supply part number: 34-0971-01
Motherboard serial number: FAA04109A5L
Power supply serial number: PAC040900QS
Model revision number: A0
Motherboard revision number: 01
Model number: WS-C3548-XL-EN <<<<<<---------
System serial number: FAA0412H0NC
Configuration register is 0xF
