06-16-2003 08:50 AM - edited 03-02-2019 08:10 AM
I have some troubles when an interface have an ip address secondary that overlaps with primary ip address, eg:
primary 10.10.0.1 /16
secondary 10.10.10.1 /24
The router running OSPF only advertises the network configured in secondary ip address (network /24 in example above). If I swap the IP address, then OSPF advertises the network /16 (now configured like ip secondary).
This issue doesn't happen if networks don't overlap, like:
10.10.10.1 /24 primary and 10.10.20.1 /24 secondary then OSPF advertises both networks.
Someone has an ideia to solve this issue???
Thanks.
06-16-2003 12:39 PM
Please show your interface and OSPF configurations.
Mark
06-16-2003 12:57 PM
My configuration is:
int f0/0
ip address 10.30.0.1 255.255.240.0
int f0/1
ip address 10.13.0.1 255.255.240.0
ip address 10.13.15.1 255.255.255.0
router ospf 10
network 10.13.0.0 0.0.255.255 area 0
network 10.30.0.0 0.0.255.255 area 0
In another router running OSPF connected in network 10.30 /20, the network 10.13/20 doesn't appear. This router only learn the network 10.30.15 /24
06-16-2003 01:06 PM
I have seen OSPF act unpredictably (i.e. it made no sense to me) when there were overlapping addresses. You may need to get rid of you overlapping addresses.
Mark
06-18-2003 11:03 AM
Can you send a copy of your complete config and routing table
06-18-2003 11:56 AM
Configuration #Router A#
interface FastEthernet0/0
ip address 10.30.0.45 255.255.240.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address 10.13.15.1 255.255.255.0 secondary
duplex auto
speed auto
router ospf 10
log-adjacency-changes
network 10.13.0.0 0.0.15.255 area 0
network 10.30.0.0 0.0.15.255 area 0
## sh ip route in RouterB
RouterB#sh ip route 10.13.0.0
% Subnet not in table
RouterB#sh ip route 10.13.15.0
Routing entry for 10.13.15.0/24
Known via "ospf 10", distance 110, metric 2, type intra area
Last update from 10.30.0.45 on FastEthernet0/0, 00:15:48 ago
Routing Descriptor Blocks:
* 10.30.0.45, from 10.30.0.45, 00:15:48 ago, via FastEthernet0/0
Route metric is 2, traffic share count is 1
06-16-2003 04:44 PM
I don't see this in my lab, on version 12.2(16.9)S. What version of code are you on? I'd open a TAC case, and see if you can track down any defect in the code revision you're running that would cause this.
Take a look at the commands I've issued below, and see if they look similar to what you are seeing (replacing the ip addresses as needed), or if they look completely different.
interface Loopback0
ip address 144.1.1.1 255.255.255.0 secondary
ip address 144.1.2.1 255.255.240.0
ip ospf network point-to-point
router ospf 100
network 144.1.0.0 0.0.255.255 area 0
network 208.0.7.0 0.0.0.255 area 0
7206F#sho ip ospf data router 144.1.1.1
Link connected to: a Stub Network
(Link ID) Network/subnet number: 144.1.0.0
(Link Data) Network Mask: 255.255.240.0
Number of TOS metrics: 0
TOS 0 Metrics: 1
(Link ID) Network/subnet number: 144.1.1.0
(Link Data) Network Mask: 255.255.255.0
TOS 0 Metrics: 1
On the other router:
2651A#sho ip route
144.1.0.0/16 is variably subnetted, 2 subnets, 2 masks
O 144.1.1.0/24 [110/65] via 208.0.7.4, 00:03:23, Serial0/0
O 144.1.0.0/20 [110/65] via 208.0.7.4, 00:03:23, Serial0/0
Russ.W
06-18-2003 12:09 PM
The router that advertise routes is running 12.1(17).
All routers don't learn routes. For example:
IOS (tm) 4500 Software (C4500-J-M), Version 11.1(10)
