OSPF and IPX in same WAN co-existing ?
gemccnp
Hi folks, We are phasing out IPX eventually in a pretty good size WAN and are using RIP currently. I just began a short time ago and am considering routing protocol choices. I would like to skip passed EIGRP and use OSPF as I feel it is a bit more efficient.
My question is, is there any harm in having both OSPF and IPX routing withing the WAN? The traffic and protocols seem so different that there should not be any problems. The IPX stuff is legacy IPX and will be going away (so they say) within a few months.
I am hoping to deploy OSPF beginning this month starting at the core and was curious if anyone has done this before.
Thanks for any help
George
ruwhite
Level 7
Level 7
There's no more harm in running OSPF with IPX than RIP/IP with IPX.... The two routing tables are seperate, the two protocols carry different sorts of information, and the two protocols use seperate hello/neighbor/router discovery.
You should be very safe with this.
Deploying OSPF is probably not that hard from RIP. I'd start by putting OSPF on the routers, and setting the admin distance really high on the osp processes. So, everything would be learned through OSPF, but not installed in the routing tables. Next, I'd plan some downtime, if possible, and go through checking each ospf database to make certain all the routing information you're after is there, removing rip, and setting the ospf admin distance back to the default.
To do this, it's best to telnet to the router closest to you, and from there to the next router, and from there to the next router (hop by hop all the way to the opposite adge from your attachment point), and do the changes there, then back out one router, make changes, back out one router, etc. This way you're not relying on routing to get to the routers that need to be changed. That's a bad thing to do when changing your routing protocol. :-)
I've seen multiple networks make this sort of transition. With good planning, and keeping your ear to the ground before and during migration, you should be fine. Note that you have to be careful of router memory if you are going to run two routing processes at the same time, as I suggested above.
Russ.W
Hey Thanks a million Russ! We will proceed with caution and good planning...
