ospf and vrf route strange question?
a network like below:
(R1)--------(R2)
(R3)--------(R4)
r2 is vrf route
all the four routes are runing ospf.if all the routes are in the same area , it work well. If r1 and r2 and part of r3 are in same area , r3 and r4 in area 0 ,it also work well.
but if in below situation,
r1 and r3,r4 is ospf area 0
r1 and r2 is ospf area 1
when you run "show ip route " on r2, there is not any route appeared . also " show ip ospf database " on r2 you can see all the route from other route , it just not put them into route table.
Why?
thanks
Gold
Re: ospf and vrf route strange question?
Not enough information, I'm afraid....
Any chance you can actually post the ospf configurations and output of show ip ospf data for the four routers? I would actually want to see show ip ospf data router on R1, if possible.
Russ.W
output of r1 shows that area 1 is a stub area.why?
I don't configure area 1 as a stub area.
sh run
Building configuration...
Current configuration : 2042 bytes
version 12.2
hostname r1
logging queue-limit 100
ip subnet-zero
no ip domain lookup
mpls ldp logging neighbor-changes
frame-relay switching
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface Ethernet1/0
ip address 30.1.1.1 255.255.255.0
half-duplex
interface TokenRing1/0
no ip address
shutdown
ring-speed 16
interface Serial4/0
no ip address
shutdown
interface Serial4/1
no ip address
shutdown
interface Serial4/2
ip address 10.1.1.1 255.255.255.0
clockrate 64000
router ospf 9
log-adjacency-changes
network 10.1.1.0 0.0.0.255 area 1
network 30.1.1.0 0.0.0.255 area 0
ip http server
ip classless
call rsvp-sync
voice-port 2/0/0
voice-port 2/0/1
mgcp profile default
dial-peer cor custom
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
length 0
line aux 0
line vty 0 4
login
end
r1#sh ip ospf data
OSPF Router with ID (30.1.1.1) (Process ID 9)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
30.1.1.1 30.1.1.1 1455 0x80000004 0x00336C 1
30.1.1.3 30.1.1.3 398 0x80000004 0x0018D7 2
192.168.0.104 192.168.0.104 398 0x80000003 0x00737E 1
Net Link States (Area 0)
30.1.1.3 30.1.1.3 1456 0x80000001 0x002788
40.1.1.4 192.168.0.104 398 0x80000001 0x000540
Summary Net Link States (Area 0)
10.1.1.0 30.1.1.1 1489 0x80000002 0x006797
20.2.2.0 30.1.1.1 1489 0x80000002 0x0032B6
Router Link States (Area 1)
20.2.2.2 20.2.2.2 1686 0x80000003 0x0044BB 3
30.1.1.1 30.1.1.1 1489 0x80000005 0x00A5E4 2
Summary Net Link States (Area 1)
30.1.1.0 30.1.1.1 1446 0x80000004 0x0025C9
40.1.1.0 30.1.1.1 388 0x80000003 0x00277E
r1#sh ip rout
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
20.0.0.0/24 is subnetted, 1 subnets
O 20.2.2.0 [110/791] via 10.1.1.2, 00:24:52, Serial4/2
40.0.0.0/24 is subnetted, 1 subnets
O 40.1.1.0 [110/74] via 30.1.1.3, 00:06:27, Ethernet1/0
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, Serial4/2
30.0.0.0/24 is subnetted, 1 subnets
C 30.1.1.0 is directly connected, Ethernet1/0
r1#
r1#sh ip ospf data router 20.2.2.2
Routing Bit Set on this LSA
LS age: 1838
Options: (No TOS-capability, DC)
LS Type: Router Links
Link State ID: 20.2.2.2
Advertising Router: 20.2.2.2
LS Seq Number: 80000003
Checksum: 0x44BB
Length: 60
Area Border Router
Number of Links: 3
Link connected to: a Stub Network
(Link ID) Network/subnet number: 20.2.2.0
(Link Data) Network Mask: 255.255.255.0
Number of TOS metrics: 0
TOS 0 Metrics: 10
Link connected to: another Router (point-to-point)
(Link ID) Neighboring Router ID: 30.1.1.1
(Link Data) Router Interface address: 10.1.1.2
TOS 0 Metrics: 64
(Link ID) Network/subnet number: 10.1.1.0
TOS 0 Metrics: 64
sh run
Current configuration : 1435 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname "r2"
ip subnet-zero
ip cef
no ip domain-lookup
ip vrf v2
rd 2:2
route-target export 2:2
route-target import 2:2
interface Ethernet0
ip vrf forwarding v2
ip address 20.2.2.2 255.255.255.0
media-type 10BaseT
interface Ethernet1
no ip address
shutdown
media-type 10BaseT
interface Serial0
ip address 10.1.1.2 255.255.255.0
interface Serial1
no ip address
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
interface BRI0
description 62359151
no ip address
encapsulation hdlc
shutdown
interface BRI1
no ip address
encapsulation hdlc
shutdown
interface BRI2
no ip address
encapsulation hdlc
shutdown
interface BRI3
no ip address
encapsulation hdlc
shutdown
interface BRI4
no ip address
encapsulation hdlc
shutdown
interface BRI5
no ip address
encapsulation hdlc
shutdown
interface BRI6
no ip address
encapsulation hdlc
shutdown
interface BRI7
no ip address
encapsulation hdlc
shutdown
router ospf 2 vrf v2
network 20.2.2.0 0.0.0.255 area 1
ip classless
no ip http server
ip pim bidir-enable
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
length 0
line aux 0
line vty 0 4
login
end
r2#sh ip ospf data
OSPF Router with ID (20.2.2.2) (Process ID 2)
20.2.2.2 20.2.2.2 1760 0x80000003 0x0044BB 3
30.1.1.1 30.1.1.1 1563 0x80000005 0x00A5E4 2
30.1.1.0 30.1.1.1 1520 0x80000004 0x0025C9
40.1.1.0 30.1.1.1 461 0x80000003 0x00277E
r2#sh ip route vrf v2
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
C 20.2.2.0 is directly connected, Ethernet0
C 10.1.1.0 is directly connected, Serial0
r2#
somebody can help me
The PE will ignored the IA routes unless the PE-CE link is in area 0. So if you were to configure the link between R1 and R2 to be in area 0 and all the other links in area 1, you would see IA routes on R2.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
98
