Bronze
OSPF default routing
My books say that to make ospf advertise a default route create a static default with 'ip route 0.0.0.0 0.0.0.0 x.x.x.x' or use the 'ip default-network x.x.x.0' statement. Then use 'default-info originate always' in the routing process. Always is required for the default-net statement. Since I'm working on a lab I cannot use the static route and I cant get then other method to work right.
Using the default-net statement the router properly advertises the default net to other routers but it does not create a route for itself to use. I put in 'ip default-net 2.2.2.0 and it generates a route statement like this 'ip route 2.0.0.0 255.0.0.0 2.2.2.0'. Anyone know whats going on here?
interface Serial0
ip address 2.2.2.1 255.255.255.252
no ip mroute-cache
clockrate 64000
interface Serial1
ip address 1.1.1.2 255.255.255.252
clockrate 64000
interface TokenRing0
ip address 20.1.1.1 255.255.255.0
ring-speed 16
router ospf 10
network 1.1.1.0 0.0.0.3 area 0
network 20.0.0.0 0.0.0.255 area 0
default-information originate always
ip http server
ip classless
Bronze
Re: OSPF default routing
Why can you not use a static route? You mentioned that because you have a lab yo ucan not use static routes.
Roger
Bronze
It is typical in a lab scenrio that it starts with a statement that says you cannot use static routes. I'm trying to understand how I would inject and distribute a default route if I was given those instructions.
Bronze
hi again
now i know what you mean...there ist one other way i can think of and thats with redistribution from an other dynamic routing protocol. But else the usual
way to do that ist with the static route. But i will check again on that tomorrow.
Roger
Gold
You don't need the default network statement to make ospf create a default route, just the default information originate command. I'm not certain where this concept of using the default network command in conjunction with the default information originate command comes from--the default information originate command can be used with a route map to get ospf to originate a default on the existance of any route in the table.
I HIGHLY discourage the use of the default network command, unless you are running IGRP. And if you're running IGRP, I'd HIGHLY recommend moving to EIGRP. So, essentially, I don't suggest using the default network command for ANYTHING at all.
Russ
Bronze
The question is how do you define a default route in that router? The default route originate makes it advertise a default, even if it doesn't have one if always is specified. The static route statement "ip route 0.0.0.0 0.0.0.0 x.x.x.x" will give it a default route to use (and propogate if the default-info orig is specified). But every lab scenario I look at starts with a statement 'no static routes are allowed'. If I run into this with OSPF is it possible?
Remember, I'm not concerned about learning or propogating the default route but creating it. Think of it as an edge router to the internet. Its not running BGP and needs a default route pointing into the Internet that it will also propogate into the interior network. Can it be done without a static route?
Community Member
All, I would like to start this up again, as I have hit the same problem in preparing for the lab and we are strongly encouraged to use the forum as a pool of resource.
It from from karl Solie's book.
Guys,
This is one of those moments where I am about to throw the CCIE Pratical
Studies book out of my window and go down the PUB!
In the book, one of the tasks is to inject a default network into the OSPF
domain without using statics.
So, I do as the book tells me and on my router I add a the following
router ospf 2002
router-id 192.168.200.200
log-adjacency-changes
area 10 authentication
area 10 stub no-summary
network 128.10.1.0 0.0.0.255 area 0
network 172.16.1.0 0.0.0.255 area 0
network 172.16.2.4 0.0.0.3 area 10
neighbor 172.16.1.6
neighbor 172.16.1.1
default-information originate always <----ADDED
ip classless
ip default-network 128.10.0.0 <----ADDED
Please note there are no static routes on thsi router as instructed.
The "default-information originate always" command injects a default route
into every router into the OSPF domain excpet this router ccie-rtr7 with the
command on. But this has a default network of 128.10.0.0 (refer to page 810
for the diag)
I do a show ip route on this router and it has a candidate default of
128.10.0.0 but no GOLR
I do exactly as the book says, but as this does not set a GOLR on ccie-rtr7,
anything for networks not in the routing table will just get dropped.
Example of debug ip packet at end.
Please help :((
ccie-rtr7#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter
area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
172.16.0.0/16 is variably subnetted, 4 subnets, 3 masks
O IA 172.16.10.0/28 [110/74] via 172.16.1.1, 00:19:06, Serial0/0.1
[110/74] via 172.16.1.6, 00:19:06, Serial0/0.1
C 172.16.2.4/30 is directly connected, Serial0/0.2
C 172.16.1.0/24 is directly connected, Serial0/0.1
O 172.16.3.0/24 [110/65] via 172.16.2.6, 00:21:06, Serial0/0.2
* 128.10.0.0/24 is subnetted, 1 subnets
C 128.10.1.0 is directly connected, Ethernet0/1
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, Ethernet0/0
O E2 11.0.0.0/8 [110/20] via 172.16.1.1, 00:19:06, Serial0/0.1
[110/20] via 172.16.1.6, 00:19:06, Serial0/0.1
12.0.0.0/24 is subnetted, 1 subnets
C 12.1.1.0 is directly connected, BRI0/0
ccie-rtr7#
ccie-rtr7#ping 155.195.1.1
Sending 5, 100-byte ICMP Echos to 155.195.1.1, timeout is 2 seconds:
01:09:37: IP: s=10.1.1.7 (local), d=155.195.1.1, len 100, unroutable
01:09:39: IP: s=10.1.1.7 (local), d=155.195.1.1, len 100, unroutable.
01:09:41: IP: s=10.1.1.7 (local), d=155.195.1.1, len 100, unroutable.
01:09:43: IP: s=10.1.1.7 (local), d=155.195.1.1, len 100, unroutable
01:09:45: IP: s=10.1.1.7 (local), d=155.195.1.1, len 100, unroutable.
Success rate is 0 percent (0/5)
ccie-rtr7#
Silver
I beleive the area 10 stub no-summary command is hosing you , remove it or make it a nssa 'area 10 nssa no-summary'
Bronze
Quite a coincidence. I was chasing this issue aga last night and the only thing I could find on the subject was my own question I asked months ago.
My routers running 12.2(1) act totally different than yours.
First off, I cannot get it to ever mark a route as a candidate using the default-network command. When I put the command in it changes it to a route statement like this
r7(config)#ip default-network 150.20.78.0
r7#sh run | b router
router ospf 10
area 0 authentication message-digest
area 30 virtual-link 150.10.6.6 message-digest-key 1 md5 ipexpert
area 30 virtual-link 150.10.5.5 message-digest-key 1 md5 ipexpert
network 150.10.7.7 0.0.0.0 area 30
network 150.20.2.0 0.0.0.63 area 30
network 150.20.78.0 0.0.0.255 area 10
ip route xxx.xxx.xx.0 255.255.0.0 150.20.78.0
I dont know where it gets the 150.20.0.0 value. Before I add that the default-info orig command feeds default routes to every attached router. After I add it it nothing changes. It still feeds a default even to the router on the default net.
And it never gets a default of its own. All these commands just make it the default for the other routers.
I started with one question, "can you give a router a default route without using a static route". I looked at the default-net statement. That may not qualify since it generates a static route. But what else is there and it doesn't work anyway.
Maybe we'll get some help this time.
Gold
The default network command won't help you distribute a default route in OSPF--it's designed for IGRP, and works in EIGRP, but other than that, it only immpacts the local routing table.
You might be able to get a local default using the default network to a network which you are learning from some other place (it has to be a classful boundary network, such as a natural class c, for the default network command not to automagically build a static route in your config), then use default information originate always to build the default to other routers in the network. Of course, if this is the trick they are playing, then it won't last much longer, because the default network command will be going away in some future release! :-)
Let me know if this works, and maybe I can think of some other way of doing it. I should get the OSPF guys to sneak in a command to do this, just to fuddle the CCIE lab guys....
Russ.W
Community Member
Hey Russ, Good to hear from you.
Thats exactly what I did.
I created a classful network (loopback) on the internet router (the one in the lab) and got OSPF to advertise this network to my router (dental-ho or in my lab ccie-rtr7), thus getting a GOLR with the IP default-network command.
The LAB in the CCIE pratical studies book tells you to use a default network of 128.10.0.0 but the lab diagram and how they want you to set it up, you cannot use the default-network of 128.10.0.0 as the ethernet interface they want you to setup is on the 128.10.1.0 /24 network.
THIS WILL FLAG the network as a candidate but not give you a GOLR as follows :-
ccie-rtr7#
This means that if there is a subnet under the classfull network, the GOLR will NOT be set.
So I created loopback 128.11.1.1 255.255.0.0 on the internet router (ccie-rtr4) and used this as a default-network on my ccie-rtr7 router and hey presto - it works :-
ccie-rtr4
interface Loopback666
ip address 128.11.1.1 255.255.0.0
ip ospf network point-to-point
router ospf 2002
network 128.11.0.0 0.0.255.255 area 0
ccie-rtr7
ccie-rtr7# sh ip route
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
Gateway of last resort is 128.10.1.9 to network 128.11.0.0
O IA 172.16.10.0/28 [110/74] via 172.16.1.1, 00:04:53, Serial0/0.1
[110/74] via 172.16.1.6, 00:04:53, Serial0/0.1
O 172.16.3.0/24 [110/65] via 172.16.2.6, 00:04:53, Serial0/0.2
128.10.0.0/16 is variably subnetted, 3 subnets, 3 masks
O 128.10.2.1/32 [110/11] via 128.10.1.9, 00:04:53, Ethernet0/1
O 128.10.0.0/16 is a summary, 00:04:53, Null0
C 128.10.1.0/24 is directly connected, Ethernet0/1
O* 128.11.0.0/16 [110/11] via 128.10.1.9, 00:04:53, Ethernet0/1
O 192.168.33.0/24 [110/11] via 128.10.1.9, 00:04:53, Ethernet0/1
You know what, it's not exactly whats in the book and I dont think it is acheivable becuase the directly connected ethernet with the /24 prevents the GOLR insertion, but we can wast a lot of time doing stuff like this, and yeah, we learn from it, but when you are on a tight schedule, it really is not much help.
Karl Solie owes me a beer I think, so mention that to him if you see him please !!
Kind regards,
Ken
Community Member
Here is a test to show that the network can have any subnets either connected or otherwise, otherwise the
GOLR WILL NOT BE SET.
remote_router2 (internet rtr)
interface Loopback1
ip address 172.16.1.1 255.255.255.0
interface Loopback2
ip address 172.16.21.1 255.255.255.0
interface Loopback900
ip address 172.17.1.1 255.255.0.0
interface Loopback901
ip address 172.18.1.1 255.255.255.0
interface Loopback902
ip address 172.18.2.1 255.255.255.0
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.10.1 255.255.255.0
duplex auto
speed auto
router ospf 1
network 172.16.0.0 0.0.255.255 area 0
network 172.17.0.0 0.0.255.255 area 0
network 172.18.0.0 0.0.255.255 area 0
remote_router config
router ospf 1
ip classless
ip default-network 172.16.0.0
set command IP DEFAULT-NETWORK 172.18.0.0 - No GOLR Set
remote_router#sh ip route
21.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 21.1.1.0/24 is directly connected, Loopback1
C 21.21.21.0/30 is directly connected, FastEthernet0/1
C 21.1.2.0/24 is directly connected, Loopback2
O 172.17.0.0/16 [110/2] via 172.16.10.1, 00:00:49, FastEthernet0/0
C 172.16.128.0/30 is directly connected, Async65
O 172.16.21.1/32 [110/2] via 172.16.10.1, 00:00:49, FastEthernet0/0
C 172.16.10.0/24 is directly connected, FastEthernet0/0
O 172.16.1.1/32 [110/2] via 172.16.10.1, 00:00:49, FastEthernet0/0
* 172.18.0.0/32 is subnetted, 2 subnets
O 172.18.2.1 [110/2] via 172.16.10.1, 00:00:49, FastEthernet0/0
O 172.18.1.1 [110/2] via 172.16.10.1, 00:00:49, FastEthernet0/0
12.0.0.0/24 is subnetted, 4 subnets
C 12.200.200.0 is directly connected, Loopback206
C 12.6.6.0 is directly connected, Loopback202
C 12.5.5.0 is directly connected, Loopback201
C 12.1.1.0 is directly connected, BRI1/0
remote_router#
set command IP DEFAULT-NETWORK 172.17.0.0 - GOLR SET
Gateway of last resort is 172.16.10.1 to network 172.17.0.0
O* 172.17.0.0/16 [110/2] via 172.16.10.1, 00:02:36, FastEthernet0/0
O 172.16.21.1/32 [110/2] via 172.16.10.1, 00:02:36, FastEthernet0/0
O 172.16.1.1/32 [110/2] via 172.16.10.1, 00:02:37, FastEthernet0/0
O 172.18.2.1 [110/2] via 172.16.10.1, 00:02:37, FastEthernet0/0
O 172.18.1.1 [110/2] via 172.16.10.1, 00:02:37, FastEthernet0/0
remote_router#
set command IP DEFAULT-NETWORK 172.16.0.0 - No GOLR Set
O 172.17.0.0/16 [110/2] via 172.16.10.1, 00:03:14, FastEthernet0/0
* 172.16.0.0/16 is variably subnetted, 4 subnets, 3 masks
O 172.16.21.1/32 [110/2] via 172.16.10.1, 00:03:14, FastEthernet0/0
O 172.16.1.1/32 [110/2] via 172.16.10.1, 00:03:14, FastEthernet0/0
O 172.18.2.1 [110/2] via 172.16.10.1, 00:03:14, FastEthernet0/0
O 172.18.1.1 [110/2] via 172.16.10.1, 00:03:14, FastEthernet0/0
remote_router#
Gold
This candidate default isn't sent to other routers as a candidate default, is it? It only impacts the local router's routing table. To get a default in the surrounding routers, you need a default information originate, or a 0/0 redistributed into the ospf process. OSPF doesn't know how to mark a "candidate default."
Oh, the _route_ is carried through the network, but you have to configure every router with the default-network command.
Russ
Bronze
Hey i think I finally understand it and it is possible, sometimes.
Heres the link:
http://www.cisco.com/en/US/customer/tech/tk365/tk554/technologies_tech_note09186a0080094374.shtml
they hid it under RIP but it talks about the default routing process in general; in great detail.
Here's my summary of it. Regardless of what you read elsewhere the "ip default-network" command is protocol independent; BUT, it is classful. That is why is always changes your command into a route statement if you entered a non-classfull network. Then you are supposed to enter the ip default-network command again for the classfull network that the ios put the route statement in for!!!!!!! Now you will have a GOLR.
Obviously it will only work if its valid to summarize the network over that next hop.
The protocol dependent part of it is entirely based on how the router will propogate the default route.
Check out the link and read it carefully, its great.
Bronze
Now that I'm over the elation of finally figuring out the ip default-network command I realized that there is still a static route in the solution and the proctor wont care that I didn't type it in. So here's the complete solution from my lab. I dont know all the restictions in the lab you were doing.
router ospf 10
area 10 range 128.100.0.0 255.255.0.0
ip default-network 128.100.0.0
The area range command summarizes the default into the classfull network that the ip default-network command will use to insert a GOLR into the route table.
r7#sh ip ro
Gateway of last resort is 0.0.0.0 to network 128.100.0.0
B 200.200.200.0/24 [200/0] via 150.10.8.8, 03:48:28
B 172.16.0.0/16 [20/0] via 150.20.2.6, 1d15h
[20/0] via 150.20.2.5, 1d15h
188.5.0.0/24 is subnetted, 1 subnets
O E2 188.5.254.0 [110/20] via 150.20.2.5, 00:08:44, Ethernet0
O E2 193.100.5.0/24 [110/20] via 150.20.2.6, 00:08:44, Ethernet0
* 128.100.0.0/16 is variably subnetted, 2 subnets, 2 masks
O* 128.100.0.0/16 is a summary, 00:08:45, Null0
O 128.100.1.0/24 [110/65] via 150.20.78.8, 00:08:45, Serial1
O 192.168.1.0/24 [110/65] via 150.20.78.8, 00:08:45, Serial1
150.50.0.0/24 is subnetted, 2 subnets
...now I'm ready for that trip to the pub you mentioned.....
Gold
What do you mean by "protocol independant?" Try an experiment. Set up a router with OSPF, no "default information originate,' or any other default command under the OSPF process, and set up a default network command. Now, go to the router's neighbors, and look at the routing table. Is there a gateway of last resort on those routers? No. You see the network you've declared as the "default network," but it's not marked as a default in any way. Why is that?
That's because the default network command will only create a "candidate default," in EIGRP and IGRP, which is carried in the protocol to all peers, etc., throughout the network. OSPF, IS-IS, RIP, and BGP all have no way of carrying a "candidate default," they can only carry a 0/0 default route.
In fact, the original reason for the default-network command was for IGRP, since IGRP cannot carry a 0/0 route at all. It was a "backdoor" way for IGRP to carry a default, without carrying the 0/0. EIGRP only carries the default network for compatability with IGRP, and no other reason. It really wasn't designed for use as a "static free way to create a default route." :-)
So, while the default network command impacts the local routing table regardless of the local routing protocols impacted, it will also not impact the information carried within the routing protocols. Does this make sense? In other words, regardless of what the on-line docs say, the default network command is only "protocol independant" in the sense that the static route command is "protocol independant." It will not generate a default route any other protocol can carry other than EIGRP and IGRP.
I hope that makes sense. In every network I see the default network command used, I always _strongly_ urge it to be removed, as soon as possible. There are a lot of reasons, not the least of which is the command is, eventually, going to be removed from IOS.
Russ.W
Bronze
It means that the default-network statement and the distribution of the default route to other routers are separate functions.
You do not have to be running any routing protocol to use the default-network statement.
Heres the quote from the doc I referenced in the link:
"If you configure ip default-network 198.10.1.0, the routing table changes to the following:
2513#show ip route
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
Gateway of last resort is 161.44.192.2 to network 198.10.1.0
161.44.0.0 255.255.255.0 is subnetted, 1 subnets
C 161.44.192.0 is directly connected, Ethernet0
S 161.44.0.0 255.255.0.0 [1/0] via 161.44.192.0
S* 198.10.1.0 [1/0] via 161.44.192.2
131.108.0.0 255.255.255.0 is subnetted, 1 subnets
C 131.108.99.0 is directly connected, TokenRing0
2513#show ip protocols
2513#
You can see the gateway of last resort has now been set as 161.44.192.2. This result is independent of any routing protocol, as shown by the show ip protocols command at the bottom of the output."
The comment at the end shows that it works with no routing protocols running.
Later in the doc is discusses how the different routing protocols can distribute the default route. They do it in different ways but they can all send it out, as long as it meets the requirements of the default-network command.
Bronze
DANG!!@#$% (censored version). I just realized that my example of using the area range to summarize the route to a classfull boundary doesn't work. It creates the router and it distributes it. Problem is it points to null0.
That does not mean that the default-net and ospf wont work together. It means that it requires a static route pointing to the real next hop to reach the summary. Thats what gets created when you enter the ip default-net statement the first time using a network that is not classful.
So I still cant figure out how to generate a valid default route with a direct or indirect static route.
321
