OSPF different Process ID within same area ????
I have 2 routers connected with OSPF SINGLE AREA 0
Router 1 Int IP as follows:
Ethernet0 192.168.1.1/24
Serial0 192.168.2.1/24
Router_2Int IP as follows:
Ethernet0 192.168.3.1/24
Serial1 192.168.2.2/24
Router_2#
Router 1 Config as follow:
router ospf 5
log-adjacency-changes
network 192.168.1.0 0.0.0.255 area 0
router ospf 10
network 192.168.2.0 0.0.0.255 area 0
Router 2 Config as follow:
no ip mroute-cache
router ospf 1
network 192.168.3.0 0.0.0.255 area 0
Router 1 routing table as follows:
Gateway of last resort is not set
C 192.168.1.0/24 is directly connected, Ethernet0
C 192.168.2.0/24 is directly connected, Serial0
O 192.168.3.0/24 [110/74] via 192.168.2.2, 00:06:13, Serial0
Router1#
Router 2 routing table as follows:
C 192.168.2.0/24 is directly connected, Serial1
C 192.168.3.0/24 is directly connected, Ethernet0
Router_2#
Why Router 2 can not learn 192.168.1.0 network form router 1 ?
2 ACCEPTED SOLUTIONS
Purple
Re: OSPF different Process ID within same area ????
When you have multiple OSPF processes on the same router, they don't communicate by default. To fix this, add the following to router 1:
router ospf 10
redistribute ospf 5 subnets
Hope that helps - pls rate the post if it does.
Paresh
Purple
The other alternative, of course, is to do this on router 1:
no router ospf 5
router ospf 10
Hope that helps,
Paresh
Purple
router ospf 10
Paresh
Purple
no router ospf 5
router ospf 10
Hope that helps,
Paresh
Thansks, it is great help.
However, WHY I can not add
router ospf 5
redistribute ospf 10 subnets
Purple
Which of the options have you tried, the first one or the second ?
Pls post the current config you have got and what you are trying to do and I'll take a look.
Paresh
The final configuration on R1 should look like this:
router ospf 5
router ospf 10
The much simpler approach would be to have only one OSPF process on R1 routing on both interfaces:
router ospf 5
network 192.168.0.0 0.0.255.255 area 0
And this should give you the desired connectivity.
Hope this helps! Please rate all posts.
Regards, Martin
193
