Ospf ...Geting stuck in INIT state .
I m configureing ospf on two router which are directly connected on ethernet segment.
but not creating neighbour relationship
geting following output
P5#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
3.3.3.3 1 INIT/DROTHER 00:00:31 50.50.50.1 FastEthernet0/
7.7.7.7 1 FULL/DR 00:00:30 40.40.40.2 FastEthernet0/
it geting stuck in INIT state.What will be the problem ?
Re: Ospf ...Geting stuck in INIT state .
Hi Ganpat,
Could you please provide the running configurations of both the routers.
Thanks .royalblues
Pls see running Config of both router.
P3 (e0/1)is connected to P5(fa0/0)
PE3# sh running-config
Building configuration...
Current configuration : 1646 bytes
version 12.3
hostname PE3
boot-start-marker
boot-end-marker
enable secret xxxx
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
mpls label protocol ldp
mpls traffic-eng tunnels
no ftp-server write-enable
no crypto isakmp ccm
interface Loopback0
ip address 3.3.x.x.255.255.255
interface FastEthernet0/0
ip address 172.20.13.2 255.255.255.252
duplex auto
speed auto
tag-switching ip
interface Serial0/0
ip address 10.10.10.1 255.255.255.252
tag-switching ip
no fair-queue
interface FastEthernet0/1
ip address 50.50.x.x.255.255.252
duplex auto
speed auto
tag-switching ip
interface Ethernet1/0
ip address 30.30.x.x.255.255.252
half-duplex
tag-switching ip
router ospf 1
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
log-adjacency-changes
network 3.3.3.3 0.0.0.0 area 0
network 10.10.10.0 0.0.0.255 area 0
network 30.30.30.0 0.0.0.255 area 0
network 50.50.50.0 0.0.0.255 area 0
network 172.20.13.0 0.0.0.255 area 0
router bgp 100
no synchronization
bgp log-neighbor-changes
no auto-summary
ip http server
no ip http secure-server
ip classless
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
login
end
P5#sh running-config
Current configuration : 1067 bytes
version 12.4
hostname P5
boot-start-marker
boot-end-marker
enable secret xxx.
no aaa new-model
resource policy
memory-size iomem 25
ip subnet-zero
ip cef
interface Loopback0
ip address 5.5.x.x.255.255.255
duplex auto
speed auto
mpls ip
ip address 40.40.x.x.255.255.252
duplex auto
speed auto
router ospf 1
network 5.5.5.5 0.0.0.0 area 0
network 40.40.40.0 0.0.0.255 area 0
ip http server
ip classless
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Purple
2 things:
- what is the output of 'sh ip ospf neighbor' on P3
- can you ping the 50.50.50.x addresses from either end ?
Paresh
Can you check by having the same configuration on
both the ethernet interfaces connected to each other.
Narayan
Thanks Narayan and paresh.
Actually i m able to ping from PE3 to PE5 but not form PE5 to PE3.and regarding configuration ,is same on both side's.
Purple
You may have to debug ospf , that will usually give you an idea why it is not coming up . Check that the MTU size is the same on both interfaces.
Hi , OSPF can be stuck in
Hi ,
OSPF can be stuck in INIT due to the mismatch in hello packet parameters such as
1. Hello/dead intervals
2. Authentication
3. Stubflag
4. Interface subnet mask
5. Area ID
MTU will come into picture when the exstart state get active (if there is an MTU mismatch it will not get into EXSTART).
17958
