OSPF Load balancing
Hi ,
OSPF supports Load balancing over equal cost path , does it do the load balancing over unequal path also ???if yes then how ?
regards
Neo
Re: OSPF Load balancing
Hi Friend,
AFAIK ospf does load balancing only for equal cost path and cannot be configured for unequal cost path.
Ankur
As to my knowledge ospf doesnt support unequal cost load-balancing.
Mahmood
I guess only EIGRP and IGRP has the capabilty of load balancing on unequal paths ?
regards
Neo
Hi Neo,
Yes you are right.
Ankur
Purple
EBGP also now has the capablility to do unequal-cost load balancing, using the dmz-link bandwidth feature.
Paresh
not to forget about MPLS traffic engineering, which allows unequal cost load balancing through different tunnels.
Regards, Martin
2079
