02-06-2004 10:27 AM - edited 03-02-2019 01:25 PM
R1 s0---OSPF---s0 R2
r1 has two loopbacks, 192.168.1.0/24 192.168.2.0/24
redistribute the two lookbacks to OSPF, right now R2 get two external OSPF routes with SAME metric, how can I give the two routes two different metrics?
I tried the below way, it doesn't work.
access-list 1 permit 192.168.1.0
access-list 2 permit 192.168.2.0
route-map net1 permit 10
match ip addr 1
set metric 100
route-map net1 permit 20
match ip addr 2
set metric 50
router ospf 100
redistribute connected route-map net1 subnet
thanks
02-06-2004 11:44 AM
try
redistribute connected metric-type 1 route-map net1 subnet
02-06-2004 12:29 PM
no.
metric-type 1 just plus something.
what I am trying is to give them exact value that I want.
just give 100 to 192.168.1.0 and 50 to 192.168.2.0
thanks
02-06-2004 02:50 PM
The cost of the link between R1 and R2 will always be factored in when calculating the metric to 192.168.1.0/24 and 192.168.2.0/24.
given that the link between r1 and r2 as a cost of 1, If you want the total metrics to be respectively 100 and 50, just set the external metric to be 99 and 49.
If that doesn't solve the specific issue that you are trying to solve, could you let you know what it is that you are trying to achieve.
Hope this helps,
02-06-2004 03:05 PM
Thanks.
still confused.
for the "set external metric", do you mean the "administrative distance", I mean "metric".
router ospf 100
distance ospf extern xx yy
for the loopback address, give them metrics respectivly is not useful, but maybe the routes are from other areas.
thanks
02-06-2004 05:58 PM
By external metric, I meant the metric that you are setting as you redistribute in OSPF. The administrative distance only has local siginficance and is used to prefer one source (static or dynamic) rather than another when a prefix is learnt from multiple sources.
Again if you told us what it is that you are trying to achieve, it would be easier to help you.
02-06-2004 06:16 PM
BB1--RIPv2---(R1 s0)--OSPF---(s0 R2 s1)--ospf---(s1 R3)
R1 learned 2 routes from BB1, 192.168.1.0/24, 192.168.2.0/24, R1 redistribute them into OSPF, by default, R3 got the external routes with metric 20, now I just want to give the two routes diffirent metric.
when I redistribute them, like
redistribute rip METRIC 100(or 50) subnet
R3 will get two routes with same metric 100(or 50), I just want to differ them.
I don't know how to do that. no special purpose.
otherwise, for "set metric 100" under "route-map", it only can be used by BGP MED? because for IGP, it seems not work.
thanks.
02-06-2004 06:42 PM
Sorry for the confusion. External type 2 will not take in consideration the internal metric, only the external one.
Your configuration should therefore do the job. You might have applied your route-map after the redistribution had already taken place. Just try forcing the redistribution by issuing a "clear ip ospf redistribution" and you should see 192.168.1.0/24 with a metric of 100 and 192.168.2.0/24 with a metric of 50 on R2 and R3.
Hope this helps,
02-07-2004 06:18 AM
exactly solve the problem. I never restart the routers or clear ip ospf redistribu. i guess the router remember the old metric for long time
thanks
