Webcast-Catalyst9k
ospf metric question
hi,
i have a 6505 router with a gigabitconnection to a mainframe.
i configured this gig-int with "ip ospf cost 5" .
on this 6505 i have other router connected.
does ospf calculate the metrics (costs) of all interfaces together ?
in other words:
does a router behind the 6505 calculate the cost in the following way:
cost to reach the 6505 PLUS cost from 6505 to mainframe (5)
thanks
1 REPLY
Re: ospf metric question
I assume your mainframe is running OSPF. If yes, the 6505 will consider the mainframe as a neighbor and should report the mainframe's linkstates to the router behind the 6505. So it will calculate the total cost as cost to reach 6505 + cost from 6505 to the mainframe = total cost to reach mainframe.
Hope that helps
76
