OSPF Process ID Question
I Apologize if this is a foolish question, but I am still learning OSPF as we migrate from EIGRP.
Does each router have to have a unique process id withing the same OSPF area?
Thank you,
DF
Re: OSPF Process ID Question
No
The process ID can be the same or different on each router it's not like an AS number on (IGRP/EIGRP). In my environment I always make my process ID the same, I like to keep everything in a uniform fashinon. You can have two neighbor routers back to back with the same or different process ID, it doesn't make a difference, they will still become OSPF neighbors as long as everything else is ok.
269
