ospf redistribute static make problem at 3640 ?
hi
i have one 3640 with 2 serial and 1 Ethernet.
each serial connected to same remote router for loadbalancing and redundant.
it have several static routes and ospf neighbor with remote router through 2 serial.
when i do shutdown 1 serial link for redundancy test. it work well.
but if test again other serial link keep going on flap ,after configure the router to do redistribute static on OSPF.
IOS version is 12.0.7T.
so i had been trying to find bug report on cisco. but i could not figure it out yet.
Bronze
Re: ospf redistribute static make problem at 3640 ?
Do you have ospf running on both serial links or only on one serial link?
And does really the serial link flap or the route?
I'm just thinking that you maybe forgot the "subnet" key word in the redistribution command.
Roger
ospf is runing on both serial link and the serial link is flap or go down therefore route is disapeared.
surely i did not mistake the "subnet" key word for redistribution.
thank you
112
