ospf router id problem
I have a 3660 router which is connected to various sites on E1 links.my question firstly is is router id duplication a problem? secondly following are the messages i got
Mar 22 12:18:15: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 172.18.109.254 from 172.18.104.254 on interface Serial2/1:1
Mar 22 12:32:06: %OSPF-5-ADJCHG: Process 20, Nbr 10.18.154.1 on Serial2/1:1 from LOADING to FULL, Loading Done
Mar 22 15:55:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/1:1, changed state to down
Mar 22 15:55:29: %OSPF-5-ADJCHG: Process 20, Nbr 10.18.156.1 on Serial3/1:1 from FULL to DOWN, Neighbor Down: Interface down or detached
Mar 22 15:57:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/1:1, changed state to up
Mar 22 15:57:11: %OSPF-5-ADJCHG: Process 20, Nbr 10.18.156.1 on Serial3/1:1 from LOADING to FULL, Loading Done
i checked the remote router at serial 2/1:1 and its router id was 10.18.154.1 ,so why did i get this message of router id duplication.
Any help?
Silver
Re: ospf router id problem
If OSPF detects duplicate router-ids, routing maynot work properly.
On a router, give "show ip ospf" command and it will show the router-id for the OSPF process on the router. Check that on both the neighboring routers. It is also possible that the neighbor router's router-id is fine, and some other router in your network has the same router-id as this router. Give "sh ip ospf database" and check for duplicate router-ids.
Also, remember after you change a router-id, I believe, you need to restart the OSPF process or reboot the router.
I did a show ip ospf at the router .
Router#show ip ospf
Routing Process "ospf 20" with ID 10.18.154.1
Supports only single TOS(TOS0) routes
Supports opaque LSA
so apparently this router doesnt even have that id which the log says is cause of duplication
Silver
I have seen this many times before . This error messaged showed up in your log because the carrier had a loop on the line on Serial2/1:1 back towards your router with the RID ,172.18.109.254 It was seeing itself in its hellos and declared a Dup RID . It this messages has ceased , I would not worry about it.
This could be a bug if your router is ASBR.
CSCdu71404 Bug Details
Headline
 %OSPF-4-DUP_RTRID_AS: Router may wrongly complain about duplicate
Product
 all
Model
Component
 ospf
Duplicate of
Severity
Status
 Resolved
First Found-in Version
 12.2(2)   All affected versions
First Fixed-in Version
 12.2(3.4), 12.2(3.4)T, 12.2(3.5)S, 12.2(3.4)B, 12.1(10.1), 12.2(4.02a)DA, 12.1(10.5)E, 12.1(10.5)EC  Version help
Release Notes
An ASBR (non-ABR) may wrongly complain about "%OSPF-4-DUP_RTRID_AS: Detected
router with duplicate router ID". This is a misleading informational message
but does not cause any adverse problems to the router.
2754
