OSPF routing between Nokia FW & 3640
I'm having a problem routing between Nokia 440 and Cisco 3640. The firewall module has not been loaded. When I do a tcpdump on the Nokia, it shows the hellos going to itself. On the 3640, the hellos doesn't seem to make it to the Nokia. Any ideas?
1 REPLY
Re: OSPF routing between Nokia FW & 3640
I am not an expert on IPSO. I believe if you have no firewall modules loaded IPSO may be using a default filter thus no allowing packets in/out any interface on the enforcement box.
http://www.phoneboy.com may have some answers on the IPSO side.
Hope this helped
Jorge
84
