OSPF Routing Issues
I have 2 routers connecting each other via LAN. Each router has 2 ethernet ports. Router A and Router B
Router A Config:
interface Loopback0
ip address 192.168.1.1 255.255.255.255
interface FastEthernet0/0
description Internal Connection
ip address 192.168.2.1 255.255.255.224
ip ospf network broadcast
ip ospf hello-interval 30
ip ospf priority 2
speed 100
full-duplex
no cdp enable
interface FastEthernet0/1
description Connection to ISP
bandwidth 6000
ip address 203.108.205.218 255.255.255.252
speed 100
full-duplex
no cdp enable
router ospf 100
log-adjacency-changes
redistribute connected subnets
network 192.168.1.0 0.0.0.0 area 0
network 192.168.2.0 0.0.0.31 area 0
passive-interface fa0/1
default-information originate always
Router B config:
interface Loopback0
ip address 192.168.1.2 255.255.255.255
interface Ethernet0
description External INterface
ip address 192.168.2.2 255.255.255.224
ip ospf priority 0
full-duplex
description Internal Network
ip address 192.168.3.1 255.255.255.0
ip ospf priority 0
speed 100
router ospf 100
network 192.168.3.0 0.0.0.255 area 1
network 192.168.1.2 0.0.0.0 area 0
But, when issue an the " show ip ospf nei" command at router B, there is no output. Neighbor relationship cannot be established...can I know why?
Re: OSPF Routing Issues
I guess there is a fault with your topology or ur interface state .. cause the Configuration seems to be okay.
do a show prot
do a show cdp neighbour
Gold
A few comments on your configuration.... Just some things I don't understand, and a couple that could be impacting your ability to build an adjacency.
Router A Config:
interface Loopback0
-- You don't need this configuration--in fact, it shouldn't print out even if you configure it (?). fat ethernet should always be broadcast.
--> You're not configuring your dead-interval as well, which might be messing you up. This is a long hello interval, and the default dead interval is only 40 seconds, so you could be dropping neighbors just because of this.
--> You don't have a network statement that covers this interface, and further, you have it marked as passive. You don't need to set the hello interval on an interface you're not running ospf on.
router ospf 100
--> You don't have any interface numbered 192.168.1.0? I think this is a typo, you intended to cover the loopback interface, but you didn't.
--> You don't have any network command covering fast ethernet 0/1, so you don't need to make it passive.
Router B config:
interface Loopback0
interface Ethernet0
ip ospf priority 0
--> You don't have a network statement which covers this interface, and you're marking it passive. Why do you have ospf commands here?
full-duplex
--> Again, you don't really need this configuration.
--> Same comment as above on the hello interval.
ip ospf priority 0
--> Why?
speed 100
router ospf 100
Second, I would turn on debug ip ospf adj--that should tell you precisely why ospf isn't building an adjacency. :-)
Russ.W
Router A
ip address 203.115.220.65 255.255.255.224 secondary
ip address 203.115.220.97 255.255.255.224 secondary
ip address 203.115.220.1 255.255.255.224
ip ospf hello-interval 8
ip ospf dead-interval 30
ip ospf priority 2
speed 100
full-duplex
no cdp enable
bandwidth 6000
ip address 203.115.200.218 255.255.255.252
ip wccp web-cache redirect out
speed 100
full-duplex
no cdp enable
router ospf 100
passive-interface FastEthernet0/1
network 203.115.220.0 0.0.0.31 area 0
network 203.115.220.64 0.0.0.31 area 0
network 203.115.220.96 0.0.0.31 area 0
network 203.115.220.248 0.0.0.0 area 0
Rauter B
interface Loopback0
ip address 203.115.220.249 255.255.255.255
interface Ethernet0
ip address 203.115.220.13 255.255.255.224
full-duplex
description Formosa Internal Network
ip address 192.168.3.1 255.255.255.0 secondary
ip address 203.115.221.17 255.255.255.248
speed 100
router ospf 100
network 203.115.221.16 0.0.0.7 area 1
Debug Message from Router B:
clear ip ospf proc
Reset ALL OSPF processes? [no]: y
formosa#
3w6d: OSPF: Flushing External Links
3w6d: OSPF: Flushing Opaque AS Links
3w6d: OSPF: Flushing Link states in area 0
3w6d: OSPF: Interface Ethernet0 going Down
3w6d: OSPF: 203.115.220.249 address 203.115.220.13 on Ethernet0 is dead, state DOWN
3w6d: OSPF: Neighbor change Event on interface Ethernet0
3w6d: OSPF: DR/BDR election on Ethernet0
3w6d: OSPF: Elect BDR 0.0.0.0
3w6d: OSPF: Elect DR 0.0.0.0
3w6d: DR: none BDR: none
3w6d: OSPF: Flush network LSA immediately
3w6d: OSPF: Remember old DR 203.115.220.249 (id)
3w6d: OSPF: Flushing Link states in area 1
3w6d: OSPF: Interface FastEthernet0 going Down
3w6d: OSPF: 203.115.220.249 address 203.115.221.17 on FastEthernet0 is dead, state DOWN
3w6d: OSPF: Neighbor change Event on interface FastEthernet0
3w6d: OSPF: DR/BDR election on FastEthernet0
3w6d: OSPF: Interface Ethernet0 going Up
3w6d: OSPF: Interface FastEthernet0 going Up
3w6d: OSPF: We are not DR to build Net Lsa for interface Ethernet0
3w6d: OSPF: Build router LSA for area 0, router ID 203.115.220.249, seq 0x80000001
3w6d: OSPF: We are not DR to build Net Lsa for interface FastEthernet0
3w6d: OSPF: Build router LSA for area 1, router ID 203.115.220.249, seq 0x80000001
3w6d: OSPF: end of Wait on interface Ethernet0
3w6d: OSPF: Elect BDR 203.115.220.249
3w6d: OSPF: Elect DR 203.115.220.249
3w6d: DR: 203.115.220.249 (Id) BDR: none
3w6d: OSPF: end of Wait on interface FastEthernet0
3w6d: OSPF: No full nbrs to build Net Lsa for interface Ethernet0
3w6d: OSPF: No full nbrs to build Net Lsa for interface FastEthernet0
Still cannot build neighbor relationship
Silver
do you have ip subnet zero configured ? in not try to enable it .
Yeap. It is enabled. Actually, the two routers are connected via Wireless link. Still no luck to establish the adjacent relationship. Any idea why? I can ping each other, but, no ospf adjacent relationship.
Silver
Why don't you try and set the hello and dead timers to the default value, also you do not need
you can cover it with one statement
network 203.115.220.0 0.0.0.255 area 0
the box will advertise all the interfaces that fall
in that range
you can do the same on router B
Can you ping between the two interfaces?
Can you see the other router with show cdp nei?
Please post the full output of "show ip ospf interface" for both interfaces?
Ian
Gold
What debug is this? It doesn't look like debug ip ospf adj, which is what we need to see why this router isn't building any full adj's. It just tells us that there's no full adj's to build a network LSA for.
Russ.W
we faced the same type of issue.we hve 2 links between 2 of our offices (leased lines).OSPF configured @ both end routers we werent able to c ospf adj once we did debug ip ospf adj we came to know that the interface/ip swapped.once we changed(swapped) the ips of the both the interfaces ospf started wkg..
regds
prem
Yes. I did turn on "debug ip ospf adj", but, there is no output message display. Can it be IOS bug?
I am using 1 cisco 2651XM router and 1 Cisco 1721 router
IOS for 1721 router
c1700-y-mz.122-4.YA2.bin
IOS for 2651XM router
c2600-is-mz.121-19.bin
You may not be sending the debug to the console. When telnetted in please enter terminal monitor at the exec prompt. Please also ensure you have "no logging console" configured,
Ian
Yes. The following is what I am getting...
1d01h: OSPF: end of Wait on interface Ethernet0
1d01h: OSPF: DR/BDR election on Ethernet0
1d01h: OSPF: Elect BDR 203.115.220.249
1d01h: OSPF: Elect DR 203.115.220.249
1d01h: OSPF: Elect BDR 0.0.0.0
1d01h: DR: 203.115.220.249 (Id) BDR: none
1d01h: OSPF: end of Wait on interface FastEthernet0
1d01h: OSPF: DR/BDR election on FastEthernet0
1d01h: OSPF: No full nbrs to build Net Lsa for interface Ethernet0
1d01h: OSPF: No full nbrs to build Net Lsa for interface FastEthernet0
There is not much useful information.
Which router is 203.115.220.249, I don't see it in your configs?
Please send
sh interface
for both routers? It looks like the other router is sending no hellos.
ian
Router A Config:
interface Loopback0
The above statement can be removed. The network will be broadcast through your ospf statements
The above statement can be removed. The default timers are normally sufficient. If you experience problems after you establish adjacencies then these can be adjusted. However, when manipulating the hello-interval the dead timer should also be adjusted accordingly.
ip ospf priority 2
Running only two routers does not really require on ospf priority statement since one will be the DR and one will be the BDR. Having this statement in will not hurt anything though.
speed 100
full-duplex
no cdp enable
CDP enable! I have experienced similar problems when I have turned this protocol off. Since it is a layer 2 protocol it discovers router b prior to ospf trying to make a connection. Enable cdp, it certainly won’t hurt anything.
bandwidth 6000
The above statement can be removed due to the fact that this interface is passive. There will not be any ospf hello packets propagated down this link.
speed 100
full-duplex
no cdp enable
router ospf 100
Remove network 192.168.1.0 0.0.0.0 area 0 and replace it with network 192.168.1.1 0.0.0.0 area 0
This statement can be removed
Router B config:
interface Loopback0
interface Ethernet0
ip ospf priority 0
These statements can be removed
full-duplex
ip ospf priority 0
I would only keep this if you want this router to always the BDR
speed 100
router ospf 100
network 192.168.3.0 0.0.0.255 area 0
sending for stansr537 next message
Router A Config:
interface Loopback0
This statement can be removed. The network will be broadcast through your ospf statements
This statement can be removed. The default timers are normally sufficient. If you experience problems after you establish adjacencies then these can be adjusted. However, when manipulating the hello-interval the dead timer should also be adjusted accordingly.
ip ospf priority 2
speed 100
I do not know why you have this statement.
full-duplex
no cdp enable
bandwidth 6000
This statement can be removed due to the fact that this interface is passive. There will not be any ospf hello packets propagated down this link.
speed 100
full-duplex
no cdp enable
router ospf 100
Remove this statement and replace it with network 192.168.1.1 0.0.0.0 area 0
Router B config:
interface Loopback0
interface Ethernet0
ip ospf priority 0
full-duplex
ip ospf priority 0
speed 100
router ospf 100
These statements are good.
istt_affin_router#s ip ospf
Routing Process "ospf 100" with ID 203.115.220.248
Supports only single TOS(TOS0) routes
Supports opaque LSA
It is an autonomous system boundary router
Redistributing External Routes from,
connected, includes subnets in redistribution
SPF schedule delay 5 secs, Hold time between two SPFs 10 secs
Minimum LSA interval 5 secs. Minimum LSA arrival 1 secs
Number of external LSA 3. Checksum Sum 0x15E75
Number of opaque AS LSA 0. Checksum Sum 0x0
Number of DCbitless external and opaque AS LSA 0
Number of DoNotAge external and opaque AS LSA 0
Number of areas in this router is 1. 1 normal 0 stub 0 nssa
External flood list length 0
Area BACKBONE(0) (Inactive)
Number of interfaces in this area is 2
Area has no authentication
SPF algorithm executed 9 times
Area ranges are
Number of LSA 1. Checksum Sum 0x7496
Number of opaque link LSA 0. Checksum Sum 0x0
Number of DCbitless LSA 0
Number of indication LSA 0
Number of DoNotAge LSA 0
Flood list length 0
This show that my area 0 is inactive which I am not sure why?
which router is this for? just curious wher the id of 203.115.220.248 came from.
Gold
So far, three people have said something about your ospf hello interval being 30, with your dead time being default. The default dead time is 40 seconds, and you're setting the hello interval to 30 seconds, which will almost gaurentee a loss in neighbor adjacency on a periodic basis.
Further, we've all made comments on your network statements, and other issues in your configuration. My first step in this problem would be to change the configurations around as three of us have suggested, and see if the problem clears up.
Russ.W
842
