Webcast-Catalyst9k
OSPF routing problem
I have very intersting problem in my network.
I will tried to describe it.
I have two computer 10.2.1.130 mask 255.255.255.0 and 10.2.1.131 255.255.255.0 conect to switch it. The router 1610 have Vlan interface configuration as following
interface Vlan1
description Lan
ip address 10.2.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
the switch is conect to this Vlan.  Also the router has FastEthernet 0 and FastEthernet 1 service two diferent provider.
track 1 ip sla 1 reachability
delay down 15 up 60
track 2 ip sla 2 reachability
delay down 15 up 60
ip sla 1
icmp-echo 172.16.10.1
frequency 5000
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 172.16.11.1
frequency 500
ip sla schedule 2 life forever start-time now
interface FastEthernet0
description PIN WAN
ip address 172.16.10.7 255.255.255.0
ip nat inside
ip ospf cost 2
delay 10
duplex auto
speed auto
interface FastEthernet1
description EOT WAN
ip address 172.16.11.7 255.255.255.0
ip nat inside
ip ospf cost 6
delay 12
duplex auto
speed auto
The ospf configuration into router 1610 is
router ospf 7
log-adjacency-changes
network 10.2.1.0 0.0.0.255 area 0
network 172.16.10.0 0.0.0.255 area 0
network 172.16.11.0 0.0.0.255 area 0
I have other two router other diferent location.Corporate location  and Data center location.
Corporate location is my router to conect 172.16.10.0 Network and get Datacenter router trougth 10.0.1.0 network it conect trougth fiber optic.
interface GigabitEthernet0/0
description PIN
ip address 172.16.10.1 255.255.255.0
ip flow ingress
ip nat inside
ip ospf cost 1
ip ospf priority 100
delay 10
duplex auto
speed auto
media-type rj45
interface FastEthernet0/3/1
ip address 10.0.1.1 255.255.255.0
ip nat inside
ip ospf priority 90
duplex auto
speed auto
router ospf 20
network 10.0.1.0 0.0.0.255 area 0   Lan to Datacenter
network 10.1.1.0 0.0.0.255 area 0    Lan to Corporate
network xx.16.x4.0 0.0.0.255 area 0  Internet
network 172.16.10.0 0.0.0.255 area 0  external offices
Data center rotuer configuration
ip address 10.0.1.2 255.255.255.0
ip nat inside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 172.16.11.1 255.255.255.0
ip nat inside
ip ospf cost 2
ip ospf priority 90
duplex auto
speed auto
media-type rj45
analysis-module monitoring
router ospf 111
network 10.0.1.0 0.0.0.255 area 0       Lan to Corporate
network 172.16.11.0 0.0.0.255 area 0  backup external network
network xx.x7.x8.0 0.0.0.255 area 0  second internet access
My problem is ping from 10.2.1.130 mask 255.255.255.0  to 10.0. 1.130 it is ok and I ping 10.0.1.150 it is ok.
Now  ping from 10.2.1.131 255.255.255.0   to 10.0. 1.130 it is ok and I ping 10.0.1.150 it is get it or get one ping four.
one way to do solution is turn off interface
interface FastEthernet1 into router 1610 after that two computer ping server with problem.
I what I apreciation help bring to work it.
Roberto Londono
437
