OSPF static route distribution
Is it possible to change the metric of a single static route, out of numerous routes being distributed (from a main site router)as a failover for the normally desired route?
The goal is to have the OSPF domain use the normal dynamic route learned from a remote site. Then if that remote site goes down, have the OSPF domain use the distributed static route, which would direct the traffic through the main site.
Is this possible?
Silver
Re: OSPF static route distribution
possible. use route-maps while redistributing
redistribute static subnets route-map setmed
route-map setmed permit 10
match ip address 101
set metric 10
route-map setmed permit 20
'101' will match the prefix. Let me know if it works for you.
Can I still do this if the router I want to apply this to is already doing "redistribute static subnets"
Can there be multiple redistribute statements?
Hall of Fame Super Silver
Richard
You have asked essentially the same original question on the WAN Routing and Switching forum where I have given a substantial answer. Rather than reproduce it here I will suggest that anyone look at that forum for the answer. Short version of the answer: I believe that a route map can control redistribution so that some static routes are redistributed with different values as Gautam has suggested. But I do not think that you need route maps to achieve your desired behavior.
To answer the follow-up question that you have asked: there can be multiple redistribute statements in the sense of redistribute static, redistribute rip, redistribute connected, redistribute eigrp 100. But there can be only one redistribute static under router ospf.
252
