12-01-2003 01:41 AM - edited 03-02-2019 12:03 PM
Can someone help?
The network diagram as below:-
Internal network --|FW|--|7204|--External Network
*********************Management Vlan
As you can see above, I have 3 FE interfaces and I am trying to make use of one to configure it to act as a management port.
Is this possible?
Please advise. Thanks.
Best regards,
Harold
10-04-2015 12:19 PM
It's easy:
create a management vrf and use the FE port in it.
10-07-2015 08:07 AM
Hi Harlod,
If you have separate Management VLAN or segment , Plug the cable from third FE port and assign Management plan ip address for accessibility.
Hope that Helps...
-GI
Rate if it Helps
