Webcast-Catalyst9k
Out of Sync problem in Startup/Running configuration Report
Hi Folks,
I have a Solaris 8 box running CW2K LMS 2.2. When I check up the Startup/Running configuration Comparsion report, I found that both are out of sync. Then I telnet to the device to confirm the configurations, however, I found that the config are sync!!! Anybody can suggest what I have done wrong/miss out in the configuration management?
Samson
Silver
Re: Out of Sync problem in Startup/Running configuration Report
You are running into bug id: CSCdw82321. The easiest way to fix this is to schedule a netconfig job for the device in the out of syncreport and do a write mem job.
Hi sbilgi,
Thanks for your help. At least I know that is a bug. However, why CW2K don't display the timestamp as it retrieved the configuration files? Does it mean that if it finds nothing change in startup/running config since previous update, it wouldn't retrieve the configuration files agian? If so, how can it determine changes have been done on either startup/running or both configuration files?
Samson
200
