Webcast-Catalyst9k
output brake
I have problem with terminal scrolling. I want to login and execute autocommand and I need output without any brake for any key press. I tried to set length 0 on vty line configuration but it doesn’t work. Maybe someone have any idea why this doesn’t work like Cisco say or maybe how to attach more that one command to single autocommand user.
Bronze
Re: output brake
Try the follwoing syntax
Router(config)# line 6
Router(config-line)# length 0
and check the URL
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_r/ffrprt1/frf003.htm#1018163
Re: output brake
Thanks but as I said before it doesn't work and I don't now why.
83
