Community Member
Output buffers swapped out increasing on interface
Whehen I do a show interface ser4/1/3 am getting the following:
147045 packets input, 28544268 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
212853 packets output, 65443543 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets 0 output buffer failures,
****9341 output buffers swapped out*****
0 carrier transitions
RTS up, CTS up, DTR up, DCD up, DSR up
Everything else looks fine. What is the significance of this? what can I do to eliminate this problem. Is it a problem? I am monitoring the situation, but so far communication seems unaffected by it. My other serial links using this serial module are fine. thanks for any assistance
1 REPLY
Silver
Re: Output buffers swapped out increasing on interface
Output buffers swapped out number gives you how many packets are swapped into DRAM(System or Main memory) from SRAM(Interface TX memory) when interface TX queue is full. In other way, how many packets are queued in backup buffer(Main memory) instead of dropping them. It's not a problem unless if you see output drops increment also. Please check the following links for more information...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/inter_r/irshowin.htm#1020497
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a758d.shtml#topicg
190
