Output Drops - ATM
I am experiencing output drops on my ATM. The load is around 50 %. Any suggestion why this occur?
Output from a show interface ATM 2/0
ATM2/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 4470, BW 7000 Kbit, DLY 80 usec,
reliability 255/255, txload 85/255, rxload 111/255
Encapsulation ATM, loopback not set
Keepalive not supported
Encapsulation(s): AAL5
4096 maximum active VCs, 1 current VCCs
VC idle disconnect time: 300 seconds
0 carrier transitions
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 03:31:27
Input queue: 0/390/0/0 (size/max/drops/flushes); Total output drops: 205254
Queueing strategy: Per VC Queueing
30 second input rate 3050000 bits/sec, 1703 packets/sec
30 second output rate 2355000 bits/sec, 1689 packets/sec
22393410 packets input, 1127164926 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
22954714 packets output, 273226211 bytes, 0 underruns
1 REPLY
Re: Output Drops - ATM
85
