Webcast-Catalyst9k
OUTPUT DROPS ON HSSI INTERFACE??? - REG
The following are the details:
7206 running IOS 12.0(21)S1 with a 2 Port HSSI Port Adapter in Simplex configuration. One port is for Uplink and the second one for the downlink. Frequently showing OUTPUT DROPS in spite of different queueing mechanisms applied. Encapsulation is FR ietf. Please throw some light on the cause of OUTPUT DROPS.
REGARDS
K. SADAGOPAN
Silver
Re: OUTPUT DROPS ON HSSI INTERFACE??? - REG
Output drops are the result of a congested interface (for example, the traffic rate on the outgoing interface can't accept all packets that should be sent out).
Here is a link showing why output drops happen and how to troubleshoot / minimize them. Without some specific interface "show commands" to see what type queuing you are using it's hard to say whats the exact problem.
http://www.cisco.com/warp/customer/63/queue_drops.html
Hope this helps your problem,
Don
the scenario is different. the output of the *show interface* is printed below.
the output is on a simplex circuit which is basically a input interface. please advice.
regards
k. sadagopan
Hssi1/0 is up, line protocol is up
Hardware is M2T-HSSI-B
Description: *******************Satellite Downlink 45 Mbps ************
MTU 4470 bytes, BW 45045 Kbit, DLY 200 usec, rely 255/255, load 1/255
Encapsulation FRAME-RELAY IETF, crc 16, loopback not set
Keepalive not set
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 13:23:01
Queueing strategy: fifo
Output queue 40/40, 908 drops; input queue 0/75, 0 drops
30 second input rate 24628000 bits/sec, 12018 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
561631387 packets input, 1942234292 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
3337 input errors, 3266 CRC, 0 frame, 48 overrun, 0 ignored, 23 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
8 carrier transitions LC=down CA=up TM=down LB=down TA=up LA=down
Silver
Since this is only an downlink all outbound packets might just be dropped. I would think that these could be control packets (ospf/cdp/etc) getting dropped as well. Are you certain that all of these are turned off on this interface?
Since
Hope this helps you,
Don
very intersting that you have 40/40 outqueue and, output rate 0 pkt/sec. Could you send us sho run int hss1/0?
Gopal
237
